IR laser vs diode laser for slate
I have just purchased a Creality Falcon 1A Pro, 20w diode laser. I also purchased the 2W IR laser module for it. I want to engrave a photo onto a slate coaster. Which laser module will give me the best resolution - diode or IR?
What is the spot size of both? SWAG tells me the IR will have much smaller spot size, ergo, finer detail.
I have only recently purchased the laser but have not yet received it. Expect it to arrive any day now. Will let you know spot sizes when I can get to their documentation and specs on that particular piece of info.
AI says this..
The spot size of the Creality Falcon 2W IR laser module is approximately 0.1mm, allowing for precise engraving on various materials.
uk.crealityfalcon.com
But, I find it hard to believe as my fiber using an F420mm is large at 50 microns, but my F100mm is only 15 microns.
Don’t confuse spot size and detail. I do rocks relatively often. The fiber has ~15 micron spot size but takes out almost 200 microns out of the material. This isn’t all rocks, but a lot of them will not (can not) produce high resolution.
No matter what your spot size is, it’s the combination of spot size and damage to the material for the most possible detail.
Check with your vendor and get what you can from them. There are calculators available on-line, such as this one that I use. It does require information on a few items that may not be readily available to you.
Good luck.
:grinning_cat:
Mark
I have the same 20w and 2wIR on my snap maker. The 2w should be about 0.03mm square…ish and the 20w 0.1x something near 0.1.
The truth is they will both be great even though the 20w is bigger it’s also faster per image.
I have only used the IR a couple of times because the 20w is so versatile for slate or wood but I’m glad to have both.
Me too. This is from the Sainsmart site for their 1w module…
With a laser spot smaller than 0.05 Ă— 0.05mm and 0.01mm accuracy
Thanks so much for the info. Can’t wait to try them both out. Trying to plan my next steps before laser arrival and set up.
Relax, learn or just become familiar with the terms used in the basic setup of hardware and software, the user interface selections/areas and how they are set out, have a few materials to get you started then go through and learn material testing in different modes like Line or fill and Image modes Greyscale and various dither patterns.
After hardware and software are ready to go, practice the material tests and how to create shapes, then fill them, join them etc etc and keep your practice work for reference with lasered notes with each test on how you did it…Speed/Power etc as refering to these will save you a lot of time trying to recall everything when its all new to you.
Post your questions to the forum with as much info as possible such as (screenshots…All info available in Lightburn Doc’s and Forum Topic search) of settings etc (not phone pic’s). State your equipment model type etc… For ages, I thought everyone was using the same equipment I was!
