I’m very happy with the running version 0.9.24. Should I chnage form a 0.-version to a 1.-version or are there still issues?
Laser Ortur Laser Master 2.
You can save all the settings from your current LB version, preferably in a different directory as the original, and test the new LB version. If you are not satisfied with the result of the latest LightBurn version, just go back to the original version (and download the setup from your backup).
Under some operating systems, you can also easily install both versions side by side, but be sure to install in different libraries, you can also rename the program names to make things more manageable.
There are (and never were) any issues I’m aware of for Ortur systems.
Bluetooth ports were added as connectable ports. Some users who never had to manually choose a port now had to do so to connect, causing some to claim that the software “no longer worked”. Clicking the port to connect to “fixes” this.
