Is it possible to roll back from 2.1.02 to 2.1.01? I am having a LOT of issue since moving to 2.1.02
Since updating to v2.1.02, I have been experiencing a multitude of issues. I get an error message now saying The connected display does not meet the minimum recommended resolution. You can still use the application, but some UI elements may not be visible or may behave incorrectly. I received a message suggesting my camera is using an old version so I updated and now I can no longer place items on the work bed - what I put on the left shows up when framing on the far right and then I get a X: SLOP error. I have changed my Start From and Job Origin points and was able to move materials around on the bed to accommodate the positions, but some jobs are just too large to be moved around on the materials. I am using a Thunder Laser Nova 24 Plus 60 Watt laser. Am I able to roll this update back to 2.1.01?
Yes, just install whatever version you want over the current one. There is no need to uninstall anything.
If things are still wonky, import a .lbprefs (Preferences) file from a date prior to your upgrade.
