OK, say you set up a Ruida that “Max Power” is 80%.
When you are in a Lightburn project and want to cut as fast as possible, do you specify Max Power at 100% in the Layer settings and under the hood scales it so that’s an 80% PWM as “Max”, or do you have to specify 80% in the Layer? Because if you entered 100%, it would just clip that and on the Ruida terminal you get an 80% PWM?
