I am making some charcuterie boards for my kids. I have 2 layers set up - basically a higher power one and a lower power one. The difference in power levels is to accomodate some extra fine detail in some of the sketching. I am using fill plus line on both layers. What would be great is to be able to have the fill of both layers done a the same time so that there is just one raster pass across the board. Is there a way to do this?
Yes, I would place both shapes on the same layer set to ‘Fill all shapes at once’ and adjust one of these shapes output using ‘Shape Properties’→’Power Scale’ to produce that shape at a different power level, yet filling both at the same time.
Thank you. I had seen the varying power levels by object in one of the test cards (candy skulls) and had forgotten all about it.
