I have my camera mount just beside my galvo lens. I use 3 lenses (70mm, 110mm and 175mm). I have it really dialed on 175MM but found if I dial it in on 110 is messes up the 175 so I assume it is a general setting and not individual to the 3 lens configs. Am I doing this right?
I would think you might be able to create a different device for each lens and camera config.
Thanks @Dskall I did create new devices for each lens. I may have done something wrong on the camera part. I went through the alignment process while in 175mm device and then used the drop down to change to the 110mm in the device list and ran the alignment again and when I went back to 175mm it was all messed up so I have been just leaving it set to the 175mm scale and using that for now.
