Is there a way to lock or put layer settings as read only?
Hi! I have 3 lasers, and we are 3 different people using them. And no one admits changing the cut settings to a dangerous power and speed combo. It would be great if I could lock them as an admin. We cut the same material over and over again
Thank you. I might suggest for your DSP controller, you can set the max limits for both speeds and power, so the operators can not exceed these limits. You could also produce an RD file and have the operators run that file.
