Hi! I´m wondering if there is an option to move center on x or y axis only to the working area? I do this every time, and have to center and then move the element. Right now you can center, and move to corners. Thanks.
Hi Gil, right now you can: center on x and y axis ( both axis, shortcut “P” ), move top left, top right, bottom left and right, left and right. What i want is be able to center some element ( shape, vector ) on the working area on the x axis OR the Y axis, attach graphic.
PD: you can align vertically and horizontally selecting two elements, but i want to do it on the working area, not align two elements.
If I understand you, is’ it this one “Move to center of Page”?
No it´s not. This option center vertically AND horizontally ( both axis x and y ) on the working area.
The least awful way may be to draw a little circle dead center on the workspace, put it on a tool layer so it won’t get into trouble, lock it in place so you can’t drag it around, then use it as the reference object for the Align Vertical Centers
and Align Horizontal Centers
tools.
Yes, quite similar of what i do, because i work with circles, thanks for your response.
Suprised that this option isn´t available, but you can align bottom left for example, thing that in a million years i will use because i don´t work with products of the same size of the workspace, but 50 times per day i have to center align design vectors on some axis.
I created a feature request with this feature if someone need something like this, vote for it. Center on work area horizontally OR vertically · LightBurn
Look at this extended menu. That may help you streamline the work. BTW - press every button on the program, try to figure out what each function is. It helps to know what is possible.
