I just went from RDWorks to Lightburn. While it does seem more stable than RDWorks, I seem to not be able to find alot of the features I have been reading about in the Forum.
Ramp is one of them.
Can anyone help me find this feature?
Rudia controller, and I manually installed my laser because I have it on WiFi.
Correct, and I was answering the question about applying a ‘Ramp’ only to shapes created within the LightBurn UI as the OP suggested. This is incorrect.
Currently and since the first release supporting ‘Ramp’, LightBurn allows the 'Ramp" to be applied to any filled shape, regardless of the software used to create the shapes.
If the drawing was created in Illustrator as vectors and you imported it as vectors into LightBurn, then yes, you can use the ramp feature with it.
If you import the design into LightBurn as an image file, you cannot use the ramp feature there. You could trace the image to convert it back to vectors. Can you show a screen shot of the LightBurn interface with your design loaded so we can see what you’re working with?
I am creating the file in Illustrator and then importing the .jpg.
I apologize…I actually worked all thru the night and have still not yet slept…So I will have to reply with the screenshots in the morning when I get back into the shop.
Ever work over 24 hours straight trying to get caught up in your shop…while trying to learn and implement new software? It does not result in positive workflow…hahahaha.
But originally I was trying to ramp a .jpg file that was created in Illustrator…to make a rubber stamp.
