I was wondering if it is possible to sort of trace (not engraving actually) path with laser before engraving like shown in gif below to indicate area which will be used for engraving. I don’t know what this is called so I’m listing this here.
If you have the Laser Fire button enabled, holding Shift when you click either of the frame buttons will enable the beam at the low power setting for focusing while the frame is run.
OMG. Thank you so much.
