Issue after adding limit switch
I have a sculpfun s10 I have ordered the limited switches and installed them following the sculpfun video instructions. I have updated the firmware which stated it was a success and then I loaded lightburn to update the area of the machine as it is lower now due to the switches which was fine and then I went to update the machine settings to update it to show limit switches installed I noticed that lightburn no longer recognises the machine. I have tried restarting everything and disconnecting everything but it hasn’t worked. I have lost all control of the laser now it just does nothing like it isn’t there at all.
I have so far tried re-installing the driver for the laser but that made no difference.
any help would be really appreciated
It’s possible the laser was assigned a different COM port with the flash. Make sure you are selecting the right port in LightBurn in the Laser window.
If that makes no difference then it’s possible you’ve had a bad flash. You may want to try reflashing in that case.
Thanks for this I have re flashed and it seems to have worked. Not sure on the exact issue but since it’s working now I won’t dig any deeper haha
Hello I got a TTS10Pro, and ahve added limit swithces. However when I started the machis, as soon as any axis (x/Y) does not touches the limit switch, the machine becomes disconected from lightburn, either from GRBL. is ther any fix?
