Issue w/ Fill on 2.0.3?
I’m trying to fill in simple fonts on a 100W Gantry laser. Previously, it would just fill in all the letters of the word line by line. Now it is doing a fill of each letter individually and taking forever. I’ve tried changing the fill settings (there seems to be a bug here too, in that the fill options are grayed out until you switch to line and then back to fill). Regardless of which setting I pick (fill all shapes at once, fill groups together, fill individually), they all behave the same way, so not sure whats going on there either.
Did something with how fill is done fundamentally change?
nvm… I finally found it. Looks like flood fill was moved to a different tab and that was enabled that was causing this.
