Issue with 2.1.0.0
Down loaded 2.1.0.0 now It seams like the laser is down on power and won’t cut 1/8 plywood. Earlier in the day I had no problem cutting 1/4” plywood. When I was done with the 1/4 plywood I downloaded the new release and it will not cut the 1/8” 20 any help would be appreciated.
Thanks, Kevin
Your units of measurement have probably been changed from/to imperial to metric and/or vice versa. How do your speeds and distances compare to the values ​​you used before? It shouldn’t be a problem to reset the default values ​​in LB back to their original values. (Units of measutement)
If the problem can’t be “just” fixed, you can always reinstall the last LB version that worked for you, then you can at least continue production.
