Issue with Cutting after moving
Greetings!
I have what I believe to be a 2nd Generation GWeike Cloud 50W CO² Machine that worked fine in the Past ( at least before moving - Today being my first Job since ). The Model does so I believe use a Ruida Controller but not quite…
The Machine connects to LightBurn as does the Camera, I can Jog the Tool Head around in all Axis ( X, Y & Z ), I can let it perform a Frame / Rubber-Band Trace to check whether the Cut is within the boundaries of the Stock Material, Libraries load just fine, etc…
BUT when I send the Job the Machine does nothing except for ramping up internally mounted Fan in the back.
I’ve tried:
  • running the current Job on both a Win10 as well on a Win11 Machine.
  • running an older, known to have worked, Job.
  • running it on 1.4.01 and 1.4.03 ( Versions after that seemed to have fixed Z-Movement direction but I cannot be bothered redoing my Libraries ).
Any suggestions? :thinking:
Never Mind… The Fill Level of the Coolant Tank went Critical and prevented any Laser Cutting :rofl:
