First issue I have ever had with Lightburn
I decided to try the Focus Test. My laser is focused
At 23.6mm. I asked the Focus Test to run from 18 to 29mm with 10 steps. The Focus Test made the lines just as they should from 18 to 29mm. The issue is when it prints the numbers at the end of each line
The laser does an auto focus 4 to 5 times everytime it prints a number. I can see it running s auto focus once per print cycle but not 4-5 times each time
At the end of the test the laser head went to 0 height and dragged the work piece over to the home position
Does anyone have any ideas on this
Thanks
This is worth review, Z Axis Controls: Device Settings - LightBurn Software Documentation
I have read that info as suggested. A guestion on the relative Z. If I use that and use 23.6mm as my start point and then run Focus Test from 18-29. Does it actually run from 18 to 29 or does it take the start value of 23.6 as 0 and actually run from 18+ 23.6 to 29+23.6?
