Issue with SCULPFUN S9 Laser Engraving Machine – DXF File Producing Erratic Lines
Hello everyone,
I’m experiencing an issue with my SCULPFUN S9 laser engraving machine, and I’m hoping someone here can help.
When using DXF files for engraving or cutting, the machine produces unexpected and erratic lines on the material (e.g., small rectangles or squares), even though:
  • The DXF file itself is simple and clear (tested in other software).
  • The cutting speed is very low (300 mm/min) to ensure precision.
  • The lines in the DXF file are straight and well-defined.
Here’s what I’ve checked so far:
  1. Software: The DXF file appears correctly in LightBurn during the preview.
  2. Laser settings: I’ve lowered the cutting speed to minimize potential errors.
  3. Mechanics: The belts and rails on the machine are tight, and movement is smooth.
Despite this, the problem persists. I suspect the issue could be related to the file complexity or the machine’s firmware.
My questions are:
  • Has anyone experienced a similar issue with DXF files and the SCULPFUN S9?
  • Are there any tips for simplifying or optimizing DXF files to avoid this kind of error?
  • Could a firmware update potentially resolve this problem?
I’d greatly appreciate any advice or suggestions. If needed, I can share the DXF file or provide more details about my settings.
Thank you in advance for your help!
Screenshot of your lightburn and photo of the results you’re getting would be helpful for someone to understand your issue. Also upload the dxf file if not proprietary so someone can inspect it.
Upload your file for us to look at. How does it look in the preview window?
Do you have a legit Lightburn license? There is similar output when using a pirated version.
Yep - it appears you do not have a legitimate version of LightBurn. You’ll need to reverse whatever you did, and purchase a license key. This is one of our piracy prevention methods.
