P.S. Thank you for adding in tool layer import again, I don’t think it was in the release notes though:
Edit: The issue seems to be when BOTH layers are linked with the material library, if I unlink either layer the issue goes away and behaves as expected.
Ok I found the issue, and I guess it means it is a bug, if the layers are linked in the material library this happens, if I unlink the layers the issue goes away
Edit: Leaving either layer unlinked the issue goes away, it seems to only happen when both layers are linked
I am not able to reproduce what you are saying. I load your file and while I do not have your library, I did link both layers with my own entries (this is why the fill looks different) and this processes as I’d expect.
By the way the it won’t let me upload .clb files here so I had to use file.io
If there is anything else I can send your way let me know
Edit: I played some more, the issue is when on my FIll layer I have “Fill shapes individually” checked, if I change to Fill groups together the issue goes away
