Issue with XY Settings in LightBurn After Updating to NEJE_v6.7.1
Subject: Issue with XY Settings in LightBurn After Updating to NEJE_v6.7.1
Hello,
I am using the NEJE 3 Max. Today, after updating to NEJE_v6.7.1.exe, my LightBurn settings got messed up. Specifically, I am having trouble with the XY direction settings between the workspace and the screen.
I tried rotating the LightBurn workspace, but I just can’t get it to match my machine correctly. I need to rotate it 90 degrees and invert the X-axis, but after trying various settings, I feel completely lost.
Could someone kindly explain how to fix this in a simple way? I managed to configure it correctly before after doing some research, but this time, I can’t seem to get it right.
Thank you in advance for your help!
Try reloading preferences from prior to update. Files>Preferences>Load Preferences
Thank you very much. I can now record and position XY in sequence. The previous orientation and home position has changed, but there are no problems, so we will continue to use it as is.
goedemorgen, ik heb een soortgelijk probleem. ik heb een grotere machine aangeschaft. alles werkte prima.de machine ging keuring naar alle punten die ik had ingevoerd. werkte perfect dus.echter,werkend uitgezet maar bij opnieuw aanzetten reageert de y as helemaal niet meer. ik heb me al helemaal rot gezocht maar kan de oorzaak niet vinden.
wat zie ik over het hoofd?
