Issues calibrating LB camera
Seems that when i try to do the alignment wizard LB thinks my laser bed is bigger so it hits the rails every time I try to cut the 1,2,3,4 I never make it past the Frame part of the wizard.
You’ll need to adjust the scale and make sure you’re using “Absolute Coords” mode when doing the alignment, or using the camera for alignment or capture.
