That’s it - Just make sure that the selected object for each target is one single object. If you make a cross-hair, for example, group it, so it is a single object.
Only group each individual set of cross hairs, that’s it. Click on cross-hair #1, then click set first target position. Click on cross-hair #2 then click set second target position. Thats it. Make sure you using “Start From: Absolute Coords” in the laser window (bottom right of screen)
What I meant was that each cross-hair object has to be “one thing” that you select. If you draw two lines for the cross-hair, you have to group those two lines so they’re a single object when selected. If you select two things it rejects it.
