Hi. I have a strange problem that I need help on. My laser is 1000mm Y and 1500mm X. I use Lightburn with a Trocen AWC708S. My system has plenty of power and there seems to be no slop with the belts etc.
If I engrave a picture using the scan orientation of zero the X Axis seems to creep back and forth.
However if I engrave with the scan at 90 then the image is perfect.
I have experimented with speeds, changing the NEMA 17 for a NEMA 23, verifying the number of steps per mm
All to no avail.
Does anyone have a suggestion.
by acceleration I did not mean the speed, but how fast the laser accelerates from 0 - Xmm / s, this value is the Acc. and if this is too high, the stepper loses steps, it looks like yours.
Hi Andreas. I found the problem.
Because nothing I was doing re settings was changing the issue I decided to swap the X and Y drivers. And that showed me that the X driver was faulty.
I replaced it with a spare and the axis is rock solid
