I have went through all the steps listed in other posts and when I attempt to launch LightBurn in the console it gives
jacob@penguin:~$ cd ~/.local/share/LightBurn
jacob@penguin:~/.local/share/LightBurn$ ls
AppRun languages lib LightBurn LightBurn.png plugins qt.conf translations
jacob@penguin:~/.local/share/LightBurn$ ./LightBurn
./LightBurn: error while loading shared libraries: libssl3.so: cannot open shared object file: No such file or directory
Any help would be greatly appreciated.
here is the first bit of the install process in case it helps
jacob@penguin:~$ sudo apt install libpulse-mainloop-glib0
Reading package lists… Done
Building dependency tree
Reading state information… Done
The following NEW packages will be installed:
0 upgraded, 1 newly installed, 0 to remove and 26 not upgraded.
Need to get 37.2 kB of archives.
After this operation, 79.9 kB of additional disk space will be used.
Get:1 https://deb.debian.org/debian buster/main amd64 libpulse-mainloop-glib0 amd64 12.2-4+deb10u1 [37.2 kB]
Fetched 37.2 kB in 1s (52.2 kB/s)
debconf: delaying package configuration, since apt-utils is not installed
Selecting previously unselected package libpulse-mainloop-glib0:amd64.
(Reading database … 33312 files and directories currently installed.)
Preparing to unpack …/libpulse-mainloop-glib0_12.2-4+deb10u1_amd64.deb …
Unpacking libpulse-mainloop-glib0:amd64 (12.2-4+deb10u1) …
Setting up libpulse-mainloop-glib0:amd64 (12.2-4+deb10u1) …
Processing triggers for libc-bin (2.28-10) …
jacob@penguin:~$ cd
jacob@penguin:~$ chmod +x LightBurn-Linux64-v0.9.24.run
jacob@penguin:~$ ./LightBurn-Linux64-v0.9.24.run
Verifying archive integrity… All good.
Uncompressing LightBurn - Better Software For Laser Cutters 100%
Removing old LightBurn…
Installing to /home/jacob/.local/share/LightBurn/
Creating /home/jacob/.local/share/applications/lightburn.desktop
LightBurn Install Complete!
