I have an 30W Integrated Fiber Laser Engraver, and according to the manual, I need to raise the scanning head until the two red dot guides merge into one to get the optimal focal distance.
The problem I have is the red dots are so bright that I cannot appreciate the right moment when the two dots merge into one (around 245mm). The lens included with the engraver is # 210D30135 and it shows “f= 210 mm”. I know that 210mm is not the focal distance as the two red dots are far from each other at that distance., but then what is f=210mm?
BTW, I am not even sure is the lens is 150x150 mm (the manual s says that) because Lightburn detected it as 110x110 mm.
Since I am experiencing some issues when engraving objects (using 245mm), I wonder if the focal distance is indeed not the optimal because some engravings have areas with different colors at the ends, one side dark and the other side white. If I try to cut a small circle out of a 0.2 mm business cards, only half of the circle is completely cut.
Is there a way to find out the optimal focal distance with just the model # (210D30135)?
