Issues with "Offset Fill" on Ortur Laser Master 3 causing Error 9
Hello,
I’m using an Ortur Laser Master 3 with an extension to 800x400mm (The most up to date LightBurn, bought two days ago). I’ve encountered a recurring issue when engraving pictures on beer coasters using the “Offset Fill” function.
Sometimes the engraving process completes without any issues, but more often than not, the process stops, and I receive errors in the console. The main errors I see are Error 9 (G-code locked during alarm state or jog state.
On or near line 0:) followed by another Error 9, which seems to halt the operation. Below is a screenshot of the console showing the errors that appear as well as the layers. The project is well within the workspace boundaries, and during the simulation of the laser path, there is no indication that the laser should leave the working area. Despite this, the error still occurs.
This is where the laser stops itself:
I’ve tried troubleshooting on my own, but I haven’t been able to resolve the issue. Any advice or suggestions on how to fix this problem would be greatly appreciated.
(My apologies for the Czech language in the console)
Thank you for your help!
Error 9 in effect means - “COntroller is in error mode. something happened”
Scroll up a bit further please you will have an Alarm3 possibly above?
Or Alarm 2
Could you copy/paste the full content of Console please?
Hi,
the whole console goes like this:
Waiting for connection…
ok
[MSG:25:USB SERIAL STREAM CONNECTED]
Ortur Laser Master 3 Ready!
OLF:206.
OLH:OLM_ESP_PRO_V2.4B.
OLM:GENERAL.
GrblHAL 1.1f [‘$’ or ‘$HELP’ for help]
[ORIGIN:China]
[PRODUCER:ORTUR]
[AUTHOR:LEADIFFER]
[MODEL:Ortur Laser Master 3]
[OLF:206]
[OLH:OLM_ESP_PRO_V2.4B]
[OLM:GENERAL]
[DATE:20220920]
[SN:9DDD80AAFF0F037BBFDC5310FDCE7735]
[VER:1.1f.20220325:]
[OPT:VNZHS+,63,32767,3,0]
Target buffer size found
[NEWOPT:ENUMS,RT+,HOME,NOPROBE,TC,SED,WIFI,FTP,TMC=7,SD,ITG,GT]
[FIRMWARE:grblHAL]
[NVS STORAGE:*FLASH]
[DRIVER:ESP32-S2]
[DRIVER VERSION:220327]
[DRIVER OPTIONS:v4.4.1-dirty]
[BOARD:Ortur Laser Master 3]
[WIFI MAC:58:CF:79:A7:12:4A]
[IP:192.168.5.1]
[PLUGIN:Power Detecter v1.0]
[PLUGIN:Power Control v1.0]
[PLUGIN:gyroscope sensor v1.0]
[PLUGIN:Trinamic v0.09]
[PLUGIN:SDCARD v1.05]
[PLUGIN:ITG STREAM v1.00]
[PLUGIN:ESP32 WebUI v0.03]
[PLUGIN:GADGET v1.00]
ok
Homing
<Home|MPos:0.000,0.000,0.000|Bf:63,32767|FS:0,0|CL:0,0|PS:2,0|VA:24424,27|Ov:100,100,100|A:SFM|H:1,7>
<Home|MPos:0.000,0.000,0.000|Bf:63,32767|FS:1131,0|CL:0,0|PS:2,0|VA:24410,24|A:SFM>
ok
<Idle|MPos:0.000,0.000,0.000|Bf:63,32767|FS:0,0|CL:0,0|PS:2,0|VA:24438,26|H:1,7>
ok
Starting stream
Stream completed in 0:14
<Idle|MPos:394.500,286.500,0.000|Bf:63,32767|FS:0,0|CL:0,0|PS:2,0|VA:24438,26|A:SFM>
ok
[GC:G0 G54 G17 G21 G90 G94 G49 G98 G50 M5 M9 T0 F6000 S20.]
Starting stream
Stream completed in 0:11
Starting stream
Layer C00
Layer C01
Layer C02
[Gyroscope: Shock and Movement detected! Check TroubleShooting Section in User Manual.]
OLF:206.
OLM:GENERAL.
[MSG:‘$H’|‘$X’ to unlock]
error:9
G-code locked out during alarm or jog state.
On or near line 0:
error:9
On or near line 0:
error:9
On or near line 0:
error:9
On or near line 0:
error:9
On or near line 0:
error:9
On or near line 0:
error:9
On or near line 0:
Job halted
Stream completed in 2:55
Thanks for the fast reply!
This is your problem here.
Your firmware is very old 206, where the Latest is 211
Is known that the early firmware was very sensitive and this caused these types of errors.
It would be important to contact support@ortur3d.com to guides on how to update firmware - as you will need to do two updates. 206 → 207, and then 207>211
Meanwhile, type this command in console
$603=0
Press enter
ALso, can you take a couple pictures of your Y belt tensioners (both sides)
Tried to take photos as clear as possible.
Left side:
Right side:
Your belts are very loose
You need to screw the little screw all the way in until none is seen
I have fixed the tensioners:
I will post an update as soon as I get in touch with the Ortur team.
Thanks for your time and help!
