Hi there!
I am using an chinese 100w co2 model with an Trocen TL-3120 controller and an cloudray power supply including the display with the milliamperemeter.
I noticed current drops while lasering since some versions and thought that it is my tube getting older. But it isnt.
I created 4 test cases where I created a rectangle using the rectangle tool in 60x20mm dimensions and set it as line 15mm/s 60% min and max power with 0.150mm offset and no other settings:
First:
LightBurn Version 1.0
Create Rectangle → Send → Origin on Controller → Start on Controller WORKS
Second:
Create Rectangle → Origin on Controller → Start in LB WORKS
Third:
LightBurn Version 1.2.01 (also tried one version before same behaviour)
Create Rectangle → Send → Origin on Controller → Start on Controller Issues with cutting and engraving. Cutting has current drops. Engraving is missing lines some times.
Fourth:
So what could be the issue? Is it an LightBurn bug? Is anyone else having this exact issue or could try it out?
Thank you!
