Issues with Y axis going down
I have issues with the Y-axis. I replaced the Sensor since it was broken but now, when I press Move Y- it gives me the
“err:limitCheck
ALARM:1
Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended.”
but when I press Move Z-, it actually goes down as if it was Y-
How do I reset the Lightburn settings or the settings on the Console command to the original ones? I think that might be the issue.
Sounds like the sensor is wired backwards and it thinks it is already on the limit switch.
Perhaps when you were replacing the switch / sensor, you interchanged the cables / plugs for the Y and Z axes?
The first comment was right. I had a faulty sensor, tried another one and it works as intended. Thank you.
