Issuies about laser frame
hi,
Can Someone explain me why the laser lights up when I do the square frame and doesn’t light up when I make the round frame, what i need to you to resolve this problem.regards
The round (rubber band) frame is just a different path method. There should be no difference between the two.
Did you try both Framing buttons in the same program?
Did this occur when using two different programs?
yes, and only work in square in strange because in not the same path but if you have the laser frame on have to work in the two wayyou don`t agree.
regards
This may or may not be helpful:
