Item coming out oval instead of round
How do I set lightburn from cutting an oval when it is supposed to be round. My project comes out like this.
First, make sure you haven’t enabled Rotary mode. Secondly, can you confirm if you’ve ever made any changes to the Machine Settings (GRBL configuration) or attempted to calibrate your axes?
Or, have you made any hardware modifications such as a change in gears or belts?
I haven’t made any changes at all. Everything should be default.
Can you run these commands in Console and return output?
$I
