I’m using lightburn 0.9.20 on windows 10 64bit, and trying to setup continuous jog mode. everything i have found is telling me to enable $J jogging and continuous jog however these options are not available. no buttons to enable this feature.
You are probably using the Grbl M3 profile which doesn’t support $J
If you are running Grbl 1.1f or newer you should be able to switch to the regular grbl profile and then enable $J
Thanks alot that worked, now when i enable continuous jog under the move tab the arow keys to jog the z axis are greyed out and only work when continuous jog is turned off, just need to find a way to jog z axis with this enabled if its possible.
