Hello,im looking advice on the settings for my j tech 7w laser,im looking to engrave onto birch plywood
Plywood is quite variable.
It’s highly advisable to run test patterns to get an understanding of how the engraver will behave with each material.
You might find some speed/power settings for Diode Lasers in Finished Creations here on the forum. Don’t expect results similar to CO2 lasers and ensure that you are working in mm/minute as the Diode engravers are quite a bit slower than the CO2 lasers. Units matter when it comes to speed settings.
