Dobrý den, jak prosím nastavím linku, aby se úplně nepřeřízla?
You would rather not cut through? Then reduce the power. Do you want to have it dashed? Then take a look at the perforation mode setting.
jde nastavit poslední milimetr linky neproříznout?
No. You can combine a line of two segments. Or you can use lead-out feature (but I don’t think this will help here) or you can use tabs and bridges, if your goal is not to have your party fall out to fast. You might need to describe your workflow in more detail…
