Jiccoda Laser lens replacement
Hello everyone :slight_smile: I have a Jiccoda LE-1 laser cutter/engraver. My lens cracked and the piece that holds it was damaged. Does anyone know where I can get replacement parts? Or if I can’t find any replacements, has anyone successfully changed the laser head on the LE-1 to a different laser head? I need some projects to get done and don’t have an operational laser.
I’d suggest you send a note to Jiccoda and see if they can help you.
This guy wrote a review, might want to ask if he knows where this is available.
You can change the module out, many people do this… I have an $80 machine that was 500mW and I changed it out for a NEJE 40630 5.5W laser module. Control signals are the same.
Good luck
I’ve been trying to email the address Jiccoda gave me previously but have not received any response for almost a month. I figure now since they don’t want to respond, I’ll just have to replace the laser module. I’ll do some research on which one would work best for my application.
Keep in mind few of these are just able to mount directly on another manufacturers setup…
Good luck
