I miss the ability to have Job Checklist transferred when switching between different laser profiles.
Could this be implemented as an option in Bundles.
Thanks
Congratulations on MillMag!
Thanks
Are you talking about Show Notes? Those notes are project specific and have nothing to do with the machine profile. If I load different profiles (I have 3 machines), the grid will readjust, but the notes stay the same for the project.
What I do, because I have a dual wattage laser, is list the Cuts settings for both wattages in the Notes. Sometimes I even have different speed/power/passes settings in different Layers of the same project. Some of my notes have SF-A9 and S30 references in them. All of this says the same thing, Show Notes is for the project.
Yeah, I can see where that would definately be a benefit.
My checklist would need all the boxes checked before I proceeded. Otherwise, I would just screw up anyhow.
…that’s why I’m glad to have this option.
Thank God the machine doesn’t run without the cooling machine starting, but don’t ask me how many times I’ve forgotten to switch my focus to the current material/task.
It actually helps that I have to press the OK button and not just “Enter”
Mine is not flipping the 40w/20w switch on the SF-A9 laser head.
Maybe I should use the Job list after all. ![]()
