I always have to flip vertical the photo or whatever I’m engraving otherwise it will engrave upside down. is there a setting in lightburn that will fix this automatically so the image is the same on the screen and how it engraves.
You need to make sure you set up your machine correctly. Do the move buttons in the move window work as expected? If not, you need to set your machine origin and job origins correctly.
          I figured it out. I put the home orientation in the back corner instead of the front left when I set the machine up.
