Job Origin Problem
I had just run a job using bottom right as job origin. Without me knowingly changing anything, the job origin is now for the whole file not the part I have selected. This is now happening for all files both existing and new files. This is happening regardless of what position I select as job origin, I have done all the obvious things like shutting down LB and the restarting. Any Ideas???
If you are only selecting part of the file, do you have “use selection origin” turned on?
Thanks Mike I don’t know how that got turned off. I have been using job origin for the last 2 years. Big thanks once again.
