How do I change the jog movement on the Move Screen? Right now mine is set at 5.00 in per move and grayed out. I am wanting to make it less. Thanks for the help!
If it’s ‘grayed out’ check the ‘continuous jog’ enable.
Where do you find this enable switch?
I have looked everywhere for it.
It is probably enabled, which would disable the ‘distance’…
No ‘distance’ option if enabled…
Wow … my screen does not have that switch on it.
Wish it did.
I have that window with the ‘continuous jog’ option on my Ruida controller… Can you post a screen shot?
You should have that option… Now you have me wondering…
What version are you on? I have had it as long as I can remember…
P.S. love your avatar
Im using the mac version of LightBurn and it might not have that.
Ill check my Windows version in the morning.
That’s not right. If that window is grayed out there must be some reason for it…
Can you do a screen shot? I’d like to see the window.
That is basic manual movement so it should be there.
If there is an issue then @LightBurn would like to know about it.
Can you get the version number? ‘Help → About’
Everyone says they have the latest version, we’d just like to double check it by the numbers…
You have to switch on ‘Enable $J Jogging’ in device settings then restart Lightburn the switch should then be visible.
And then reboot LightBurn.
Ahhh , there is where they hid it …lol.
Thanks once again Mooseuk …
Thank you all for your help! Sorry for the late reply. The answer that was given about toggling the Continuous Jog button worked. I thought I had tried that but apparently I did not. Thanks again for the help.
Glad that fixed it…
If the thread is ‘solved’, please mark it so…
Good luck
Take care
