Jpeg file can not be downloaded or Imported? Size limit on Photo?
Wiil not download/import 2meg Jpeg File(Picture)?
Very strange i just imported a 10Meg picture with no problem. Do you get any error message or anything? Im thinking maybe it is trying to import but your machine is taking its sweet time. I run an SSD hard drive, and everything is pretty instant!
Thanks, One Jpeg goes in right away and the other says “does not support”. Files are pictures downloaded from iphone. Is there a difference between Jpeg files?
Are you certain the iPhone image having the problem is not an HEIC file? I believe iPhone changed their default file format to HEIC a while back.
I found that if I move the file Jpeg into Microsft Photos, then save it is acceptable in Lightburn & GrBL!!
