You’ve give us nothing to help you with. Just a vague question and a copy of your device settings.
We know you know, but we don’t.
Which functions are not working?
power and frequency gives 10 percent power of the machine ezcad2 I get power without any problem, it does not happen in lightbrun
As far as I’ve seen the source has an 8 bit power input setup. I don’t see how it would work at all if it didn’t go down to lower power levels also.
Mine has MO enable ONLY when running, but I doubt that has any effect.
You could change the fiber type and see if that makes any change.
I assume you’re sure you’re focused.?
