Hi all, wondering whether we can use Lightburn with the k40 laser unit (m2 nano baord), understand this board does not support power control though was hoping to set the power using the units on board power settings. Is there a device we could select from the add new device wizard that may be compatible ?
Unfortunately lightburn will not with with the nano board. You will need to upgrade the board I order to use lightburn.
Ok many thanks…
