Thank you Jack! I edited the post and labeled the pictures, they are basically 30,50,70,100% from low volts to 3.3V I’ll double check the volt output but I think I received a bad board. I’ll contact Monport and see about a replacement. In the meantime I’ll do some research on the TEM0 mode test.
Also my S value is 1000 and $30 is 1000
Again, Thank you for all of your help!
Kevin Parks
Monport finally responded after I told them that I think I have a bad board. They sent me an email on how to adjust my LPS output. The laser worked perfectly fine with M2Nano board and K40 Whisperer, I just wanted to be able to use Lightburn on it.
This would suggest that the lps is OK and in no need of adjustment.
I don’t think you can turn it up enough to get the proper power out with a pwm of only 66%. This also makes it really tough on how to guesstimate power…
I’m really at a loss for a good suggestion. If the board isn’t producing the proper output, it isn’t ever going to work…
The video runs fine … did they tell you what to adjust it to, mA wise?
I am getting a change in mA. In this post from the other day i was trying to run a test and record the volts in and the mA out at the same time and I don’t think I was getting accurate V readings. I was using my multi meter to test volts and the machines mA meter to watch the mA’s.
As a synopsis… if you double the power from 20% to 40% you only increase the current by 1mA…
Increase it by 50%, to 60% power, the increase in current is doubled.
A bump from 60% to 80% or a 33%, increases it the current by 60%… this isn’t right.
This isn’t going to be exactly linear, but it should be reasonably close.
I do my lps like they suggest… however, I set the percent power to 50% and set the pot in the lps to 50% of my maximum current value… I don’t think that’s going to work with your machine.
I also purchased ceramic screwdrivers for poking around when high voltage is present. 30kV can be very enlightening, but it’s not very pleasurable.
My lps pot adjustment requires you to be a contortionist. Taken from the little access panel on the rear…
Thanks Jack, I’m going to try to test it again this weekend and see if I can find the lps adjustment screw. I’m going to figure out if it’s even possible to safely adjust it will its inside the K40. I’ll post back if I can get more accurate % to V to mA reading. I have to figure out my max mA, I think i seen like 17mA is a safe max mA but I’m not sure.
