Keeping aspect ratio on individual objects while scaling, how?
That makes good sense :+1:
I was wondering…
Is there a fast way to add circles to the center point of the peg holes that are none circular?
I can manually add a 1 x 1 mm circle to all the “skewed” peg holes, so they fit to center point. This could be an option maybe, but it would be easier to have some kind of “search and replace”, if you get my point?
You could create the circle prior to duplicating both shapes as required.
But if what you’ve described of the shapes is true, you shouldn’t need to do that as this approach should work for the shapes you’ve described.
