Kentoktool JL5 no laser
Ok, im losing my mind here, Kentoktool JL5 ( dont rip on me, its all i could afford) the laser was working fine yesterday, actually cleared several issues, today, the laser wont fire. The 3% laser will turn on from the machine itself but the 2% for framing and full power laser wont turn on. Laser head moves as if its engraving, but no laser. I havent changed any laser controls, just image settings. The laser might have 100 hours on it. The computer, software and laser have been power failed and restarted several times, no change. Can anybody point me in the right direction or do i throw it all into the street?
Check the Laser on when framing button in the Cut settings window.
The laser is randomly on when framing. It will not fire ( turn on) to engrave a project
That is a better explanation.
Reduce your Frame power and see if it stays on.
Could be loose connector, broken wire, or bad power supply.
Make a 5mm square and see how that operates.
Make a 150mm square and see how that operates.
Report your results for both.
