Pozdrav,
Imam jedno pitanje. Prilikom graviranja i rezanja kada moj laser ide od tačke A do tačke B ne gasi se nego ostavlja prelaze ucrtane u materijal.
Kako da ugasim tu opciju?
Hello,
I have a question. When engraving and cutting when my laser goes from point A to point B it does not go out but leaves transitions drawn into the material.
How do I turn off that option?
Da bas tako, radi u praznom prostoru. Koristim lightburn zadnju verziju, te me zanima kojom komandom cu ugasiti laser prilikom kretanja u slobodnom prostoru. Btw hvala na odgovoru
Yes, that’s right, he works in an empty space. I am using the latest version of lightburn, and I am interested in which command I will use to turn off the laser when moving in free space. Btw thanks for the reply
What motion control system / controller is used to drive this laser?
I saw ‘Tree’ listed in your profile, and thought you are working with a GCode based system. Looking again, I see you also list 80W. Very different from what I was thinking, sorry for that.
