KT332N Cont. and Light Burn
Since you have a couple of these … I can leave off the kit gloves…
It’s telling you it will go out of the machine space if it proceeds. If it specifies an axis, that axes is going out of bounds.
Both ‘start from’ and ‘job origin’, and origin set on the controller. If you run ‘absolute coords’ does it frame.
In simple terms, you think it’s in the work area, but it knows differently. So, something is not configured properly or you are mistaken about size… If you try to ‘save’ a file that Lightburn knows is too large, it will warn you.
So I’m betting it’s not setup somehow.
Can you jog it the proper directions with the Lightburn ‘move’ and/or console?
Does the X and Y coordinates in the controller window increase/decrease in the right directions?
