Lack of power sculpfun s9
Hello, my sculpfun s9 is having problems with low power engraving, can anyone help. Cant upload a video if anyone can help i can send it
Hi Marcio
You can use Google drive or other of your choice to upload a video, then post the link here and make sure its available to all viewers.
Have you used the machine before and it worked ok?
Is your ‘S value’ (in settings set to 1000)
Have you got the Focus distance optimised.
If you post some screen shots of your settings, that might help as much as a video…but as much info as possible is best.
Does your S9 have air assist? If not, put dirty lens on your list.
I installed a new head and the problem persists
The Troubleshooting guide may help:
And Sculpfun machines have @misken’s comprehensive guide:
got a new head, lens are new and the problem persists, chechked the adapter and its ok.
This indicates you might need to get a DVM and do some voltage checking. But first…
Describe your project:
  1. Material you are etching
  2. Speed in mm/m
  3. Power %
