I’m having an issue with my laser engraver and the camera system in LightBurn. I’ve done a few test points using the laser fire tool (not actual engraving, just firing the laser at a specific location), and then used the GPS icon in LightBurn to move the laser back to those same spots using the camera overlay.
Here’s the problem: the actual engraving happens around 3-4 cm to the right and about 1.5 cm lower than the target point shown in the camera view.
Even though my coordinate system seems correct and the camera is properly calibrated — at the same height as my material — it’s still way off.
I tried using the Laser Offset Adjust settings in LightBurn, but that either doesn’t change anything or makes the misalignment even worse.
My Engraver: Sculpfun S30 Pro
Has anyone else run into something similar? Could it be a camera alignment issue I’m missing, or is this something deeper in the LightBurn settings? Any help would be appreciated.
