Just upgraded from leetro to ruida RDC6445S-B
I have two issues one is engraving massively overshooting which i can work on but more pressing issue is the laser is firing constantly.
Its off when idle but when jogging, framing and doing a job the laser is constantly one. I’ve check my wiring and made adjustments and so far without luck can anyone shed any light on this?
If that is the way it’s wired and the laser tube still remains active, then the controller must be configured to use low-active signalling. In LightBurn
Go to Edit → Machine Settings
Click on the tiny triangle in Vendor Settings and agree you won’t wreck anything
In the Laser 1 Output Signal line, select Low from the dropdown
My KTN332N is different from your RDC6445S, so the actual option will surely use different words, but you’ll find something similar.
And if that setting doesn’t make the laser behave, then something weird is going on.
Thank for your message, I checked vendor settings it is set to low already. I’ve tried to trace the L-ON1 back buck cant see an obvious labelled layout like your image.
Thanks I’ll give that a go tomorrow
The laser will cut, seems to adjust power (although always on) so this is a good sign there nothing that needs replacing I’m sure just really stumped on this.
I’ve adjusted the wiring again and in vendor settings ive turned off tube 2 and now its working almost completely correctly.
The laser will still fire at a very low power when moving not whilst jogging or resetting now only whilst in operation.
Material will cut fine but if the laser travels over the material it will leave a score line shooting around 0.2ma
Do you have the Machine settings → Laser settings → tube type set to glass?
Doubt this is a solution, but there is nothing that I know of that will allow such a small current of 0.2mA… Most dc excited tubes won’t lase below about 10 to 20%…
So, Ruida wired up correctly.
Laser is working but but when traveling it is shooting 0.2ma causing light scoring to the material.
Leetro is normal connecting to the high pin (wire leaving the PSU) this need to be switched to the Low pin and should fix the issue. I’ll update when this is done and then this can be closed off with a solution hopefully.
When it’s just moving, it should not have the laser enabled. If it was inverted, as you claim, then it would lase at that layers power, not 0.2mA… Most machines will not lase at this low of a level. It should also reverse the engraved with the non-engraved…
