Laser bed lower in one corner
On my Omtech Pronto 40 I am assuming it’s always been this way and I just never noticed but now that I have it’s driving me nuts. The magnets I use happen to be the perfect focal distance gauge so I always use them but I noticed yesterday that the bottom right corner seems to be almost double the distance from laser nozzle as the top left. So I checked the bottom left thinking maybe it’s sloped, nope seems to be the same as the top left same thing with the top right. So I thought maybe my honeycomb is warped so I pulled it and it seems to be the same thing with the blade bed as well so the problem has to be in the screws that lift/lower the bed. Anyone have any advice on how to tackle this issue? First time having anything like this happen so I’m kind of lost
These usually have 4 screws that control table height. Usually you can disconnect the belt and turn that one screw, the put the belt back on.
:grinning_cat:
Thank you sir! I shall give that a try
Easy fix with the advice, I appreciate you!
If it won’t adjust perfectly, some have a set screw (grub screw) you can loosen and move the pulley/screw assembly to correct for tooth offset.
Glad if fixed you up.
:grinning_cat:
