Laser Bed Nail Board
I made a couple of laser bed nail boards for my Creality Falcon Module on my Ender 3 V2.
I originally made this model for a nail board, that used the bamboo cutting board from Dollar Tree.
I started by making a template in Fusion 360 and exporting a DXF file for LightBurn. (The export is completely doable with a personal license - with just a few extra steps)
And glued some magnets on the bottom to keep them from moving around.
I used:
2 ea. Dollar Tree Bamboo board
1 ea. Dollar Tree 9 x 13 Aluminum pan
3 ea. Home Depot #16 x 1-1/4in Wire Nails (1oz package)
Laser Bed Nail Board.lbrn2 (29.8 KB)
Laser Bed Nail Board.dxf (29.9 KB)
Guess you nailed it… :wink:
Looks good… how level is it and how does it work…?
It’s beautifully level, and so far the cuts look great!
The nail tips are about 1 inch from the board. And so there are faint marking on the wood after a cut.
I can see some potential problems with wanting to use magnets to hold something down / flat.
But, with a little experimenting, I’m sure that I will find the right magnets
I just wanted to add that Magnets work so much better than I originally expected them too. They simply align themselves on the tips of the nails without any extra shifting around.
I did something similar, used screws, lots of 'em.
But I found “mending plates” at Lowe’s. The small square “nail plates” you see on the frames of new houses. I like them because they’re shorter.
nice one i had a go with the same and it worked great until i tried this with steel plate and some punk rocker studs
image_2023-07-02_211301018
OMG this is fantastic hahahaha! As an old NYC punk, I salute your punk laser, sir. Well done.
