RBrewer91
(Robert Brewer)
December 16, 2021, 12:26am
1
Hey everyone,
So an issue started last night where scaling seems to be off from LightBurn to my Ortur Laser Master 2.
For instance, when I draw a 4"x4" square in LightBurn, my laser burns it at about 4.25"x4.25".
Please help! I haven’t been able to find much on this issue.
berainlb
(PY)
December 16, 2021, 12:32am
2
Has anything changed recently? Did you recently use a rotary or change any configuration parameters?
RBrewer91
(Robert Brewer)
December 16, 2021, 1:09am
3
I did use a rotary, but I have all settings saved for normal engraving or rotary use.
berainlb
(PY)
December 16, 2021, 1:45am
4
Can you issue $$ in console and return here? This is likely something config related.
Have you actively compared your saved settings to the current reloaded settings?
RBrewer91
(Robert Brewer)
December 16, 2021, 2:09am
5
It starts working correctly out of nowhere. didn’t change anything. fresh spoil board and burned same squares but now they are correct.
Project loaded in 9 milliseconds
Waiting for connection…
ok
[AUTHOR: ORTUR]
[MODEL: Ortur Laser Master 2]
[OLF: 140]
[DATE:13:36:28 - Dec 31 2020]
[VER:1.1h.20190903:]
[OPT:VNZHI,99,254]
Target buffer size found
ok
Homing
ok
ok
ok
Starting stream
Layer
Layer
Layer
Layer
[MSG:Pgm End]
Stream completed in 1:43
$0=2.000
$1=25
$2=0
$3=0
$4=0
$5=0
$6=0
$10=3
$11=0.050
$12=0.002
$13=1
$20=1
$21=1
$22=1
$23=7
$24=600.000
$25=3000.000
$26=100
$27=3.000
$30=1000
$31=0
$32=1
$33=250.000
$50=0
$100=80.000
$101=80.000
$102=80.000
$110=9000.000
$111=9000.000
$112=1200.000
$120=2200.000
$121=1800.000
$122=2500.000
$130=400.000
$131=430.000
$132=1.000
ok
ok
$0=2.000
$1=25
$2=0
$3=0
$4=0
$5=0
$6=0
$10=3
$11=0.050
$12=0.002
$13=1
$20=1
$21=1
$22=1
$23=7
$24=2000.000
$25=3000.000
$26=100
$27=3.000
$30=1000
$31=0
$32=1
$33=250.000
$50=0
$100=80.000
$101=80.000
$102=80.000
$110=9000.000
$111=9000.000
$112=1200.000
$120=2200.000
$121=1800.000
$122=2500.000
$130=400.000
$131=430.000
$132=1.000
ok
Rotary setting update successful
ok
ok
Starting stream
Layer
Job halted
Stream completed in 0:24
ALARM:3
Reset while in motion. Grbl cannot guarantee position. Lost steps are likely. Re-homing is highly recommended.
ok
Ortur Laser Master 2 Ready!
OLF 140.
Grbl 1.1h [’$’ for help]
[MSG:’$H’|’$X’ to unlock]
[MSG:Caution: Unlocked]
ok
ok
ok
Starting stream
Layer
Job halted
Stream completed in 0:04
ok
ok
ok
ALARM:3
ok
OLF 140.
ok
ok
ok
Starting stream
Layer C14
Layer C14
Layer C14
Layer C14
[MSG:Pgm End]
Stream completed in 1:24
ok
[AUTHOR: ORTUR]
[OLF: 140]
[OPT:VNZHI,99,254]
ok
Homing
ok
ok
Starting stream
Layer
Job halted
Stream completed in 0:20
ok
ALARM:3
OLF 140.
ok
ok
File imported in 17 milliseconds
ok
ok
ok
Starting stream
Layer
[MSG:Restoring spindle]
Layer
Layer
berainlb
(PY)
December 16, 2021, 2:14am
6
That’s good… but not comforting. Let’s hope it holds up.
system
(system)
Closed
January 15, 2022, 2:15am
7
